1991 Cadillac Eldorado Window Only Part Way
COUNTRYBOY1369
1991 Cadillac Eldorado 89000 miles. the front passenger window was broken then replaced and now will only roll down part way. they are power windows.Ive checked every manual and cant find out how to fix it
Aug 25, 2007 at 8:51 AM
  • 55,770 POSTS
remove the door panel and check for an obstrution in the way of the window regulator.
Sep 18, 2007 at 3:35 AM
BUZZSAW
  • 1,198 POSTS
[quote:893fe59543="countryboy1369"]1991 Cadillac Eldorado 89000 miles. the front passenger window was broken then replaced and now will only roll down part way. they are power windows.Ive checked every manual and cant find out how to fix it[/quote:893fe59543]
the motor could be bad also, flat spot on armature
Sep 21, 2007 at 3:03 PM
Suggested Repair
Remove the door panel and check for an obstruction in the window regulator path. Also inspect the power window motor, which may have a flat spot on the armature.
Conversation Summary
The owner of a 1991 Cadillac Eldorado says the front passenger power window was replaced after it broke and now only rolls down partway. Experts suggest removing the door panel to check for an obstruction at the regulator and also checking the window motor for a flat spot on the armature.
