1994 Cadillac Eldorado Stuck Brakes
CADDYMAN08
1994 Cadillac Eldorado, 4.6L Northstar, 123,000 mi., FWD.
A couple of days ago, I replaced my rear brake pads. Then gradually, I could feel a difference in the way the car would accelerate and the amount of throttle required to stay at a constant cruising speed. Eventually it got to the point at which pulling away from a green light, I would have to use full throttle to get the car to move. I had had problems with my RR brake caliper and replaced that 2 days ago and the pads (brand new) were already started to wear and the inside pad was burnt. New caliper now installed and again, today, the car would not even move at all at a green light for quite a while until I put it in park and reverse and whatnot and then it finally started to roll again. What could possibly be causing this? Collapsed brake line? Bad master cylinder? Any help is very greatly appreciated. Thanks.
Rick May
Jul 4, 2007 at 11:12 AM
MERLIN2021
  • 17,250 POSTS
2 things to check, Cheapest is check the parking brake cable, see if the rotors will spin free with calipers unmounted. If not open a bleeder and see if the rotor will turn. If the bleeder releases pressure, you have a hose or master problem. If it's the master, all 4 will be dragging.
Aug 13, 2007 at 8:47 AM
Suggested Repair
Check the parking brake cable and whether the rotors spin freely with the calipers unmounted. If they do not, open a bleeder; if that releases pressure, suspect a collapsed hose or the master cylinder. A faulty master cylinder would drag all four brakes.
Conversation Summary
The owner of a 1994 Cadillac Eldorado reports severe brake drag after replacing the rear pads and a right-rear caliper. The new pads wore quickly, the inner pad burned, and the car eventually would not move. The expert advises checking the parking brake cable, confirming the rotors spin freely with the calipers off, and opening a bleeder to see whether trapped pressure indicates a hose or master-cylinder problem.
