2000 Eldorado - Blower won't blow
2000 ALL OTHER MAKES ALL OTHER MODELS
HOPEIN
I have a 2000 Eldorado that the blower won't blow. The heater and defroster works and the ac works but the blower won't blow. If you set it for fresh air heat is pushed through the system and the window will defrost and heat will come from the vents.
Jan 10, 2007 at 3:11 AM
BOOTDOG
  • 665 POSTS
if the blower motor doesn't work, then the first thing i would check is a blown fuse or relay. if thats fine check to see if you have power going to the blower motor. if there is power there, and the ground is good, and it still doen't work, then replace the blower motor.
Jan 10, 2007 at 7:17 AM
HOPEIN
[quote:ea95a57513="bootdog"]if the blower motor doesn't work, then the first thing i would check is a blown fuse or relay. if thats fine check to see if you have power going to the blower motor. if there is power there, and the ground is good, and it still doen't work, then replace the blower motor.[/quote:ea95a57513]
Thanks for the reply - I have checked the owners manual and it doesn't list any fuses for relays for the blower - do you have any idea where they are
Jan 12, 2007 at 2:27 AM
BOOTDOG
  • 665 POSTS
under the dash on the drivers side, and also under the hood, look fo a power distribution box. remove the cover and there will be a list of the fuse/relays function.
Jan 12, 2007 at 9:08 PM
