1992 Cadillac Eldorado Gauges Out
ANGELO FRANKLIN
1992 Cadillac eldorado 171000 miles.
Runs exceptionally well, but here recently speedometer and fuel gage stopped working.
Also buttons on panel,i.e. information,data, reset buttons not working on panel.
Strangely enough tachometer is working.
Before I take it in for repair what should I tell the mechanic to look for. (4.9 v8)
Nov 19, 2007 at 1:35 PM
2CARPRO JACK
  • 11,533 POSTS
Sounds like there may be a bad connection in the dash somewhere.Have the Bulkhead and other main connectors checked for corroded terminals and moisture.
Nov 20, 2007 at 4:00 AM
Suggested Repair
Have the mechanic check the bulkhead and other main dash connectors for corroded terminals and moisture, which can cause the speedometer, fuel gauge, and panel buttons to fail while the tachometer still works.
Conversation Summary
The owner of a 1992 Cadillac Eldorado reports that the speedometer, fuel gauge, and information, data, and reset panel buttons stopped working, while the tachometer still works and the car runs well. The expert suggests a bad dash connection and recommends checking the bulkhead and other main connectors for corroded terminals and moisture.
