1998 Cadillac Eldorado Not Charging
REDGLIDER121
Cadillac Eldorado 1998 81,000 miles 4.3 literV8
computer message--Battery Not Charging
Then computer message 13.8volts and then voltage going down in computer until message says Battery not Charging. Car will not start - first time this happened no warning.
Jul 13, 2007 at 9:57 AM
MERLIN2021
  • 17,250 POSTS
Most newer car need the alternator and battery replaced together. If you do the alt and the Batt is weak, the new alt "Dies"!
Aug 13, 2007 at 8:42 AM
Suggested Repair
Replace the alternator and battery together. A weak battery can damage a new alternator if only the alternator is replaced.
Conversation Summary
A 1998 Cadillac Eldorado showed a battery not charging message, with displayed voltage falling from 13.8 volts until the car would not start. The expert advised replacing the alternator and battery together because a weak battery can ruin a new alternator.
