1999 Cadillac El Dorado Intermentent no start
LLOYD BRADY
Electrical problem
1999 Cadillac El Dorado V8 Two Wheel Drive auto 57,000 miles
I have a 1999 eldorado when it sits for a couple days it will not start.Everything comes on far as interior lights but no crank.Then i wait a few minutes,and the car fires up.The battery is brand new the cables look great.The alternator reading on the dash is reading 14.3 volts so I know its charging.Also Notice this promblem getting worse now its winter were before it only did it some times.Any help why its doing it would be greatly appreciated.
Dec 7, 2007 at 12:20 PM
2CARPRO JACK
  • 11,533 POSTS
Is that a Northstar?....Should be 4.6l Need to start by checking the starter trigger wire for 12 volts when key is in crank position.Bad news is that the starter on this is under the intake manifold.The starter trigger wire should be right next to the battery cable where it goes under the manifold. Front top of engine closest to battery. If it has it, starter is bad, if not get back to me.
Dec 8, 2007 at 12:08 AM
BUZZSAW
  • 1,198 POSTS
[quote:e88476591c="lloyd brady"]Electrical problem
I have a 1999 eldorado when it sits for a couple days it will not start.Everything comes on far as interior lights but no crank.Then i wait a few minutes,and the car fires up.The battery is brand new the cables look great.The alternator reading on the dash is reading 14.3 volts so I know its charging.Also Notice this promblem getting worse now its winter were before it only did it some times.Any help why its doing it would be greatly appreciated.[/quote:e88476591c]
ck for cables being loose or corroded at the battery
Dec 10, 2007 at 5:21 AM
