1994 Cadillac Eldorado No Start After Hub
When your front driver side hub was changed,something may be done to the speed sensor. the ABS sensor ring is located just before the outer CV joint.
The sensor must be at a specified distance from the ring in order for the sensor to work properly,an that distance is term of air gap.
use a plastic feeler gage after determinig the air gap distance from the service manual.
It could also be that the tone wheel or exciter ring is damage due to the work done around that area.
your starter may not working, the click you hear is the solenoid.
Suggested Repair
Treat the warning lights and no-start as possibly separate issues. After the hub repair, inspect the ABS speed sensor and tone/exciter ring near the outer CV joint, and set the sensor air gap with a plastic feeler gauge to the service-manual specification. Also recheck the starter, since the click may be the solenoid and the starter may not be engaging.
Conversation Summary
A 1994 Cadillac Eldorado with a 4.6L DOHC engine will not start after the front driver-side hub was replaced; the starter only clicks, and the ABS, brake, and traction-control warnings are on. The owner says the starter and solenoid are good. The expert says the hub work may have disturbed the ABS speed sensor or damaged the tone ring, so the sensor air gap should be checked, and that the click may indicate the starter is not actually working.
