If you want to try and eliminate a possibility, disconnect the sway bar links from the strut or the sway bar. If the noise is gone, replace the link(s). If the struts are the problem, replacing them is the only possibility. You also need to consider the upper strut mount/bearing.
SPONSORED LINKS
Thursday, January 21st, 2010 AT 10:04 PM
