Back passenger tire is wobbling when driving.
178,987 MILES
JUSTINMACK
The back passenger tire wobbles when driving even at speeds as low as 30 mph. If you jack the car up and shake the tire from side to side and up and down it moves quite a bit. The other side is fine. The lug nuts are tightly secured so I don't know what the problem could be.
Apr 20, 2016 at 3:19 AM
HMAC300
  • 48,601 POSTS
it's probably a bad wheel bearing or a bent wheel. take tire off and roll it you'll see if it's bent but i'd go with the wheel bearing.
Apr 20, 2016 at 5:40 AM
JUSTINMACK
Would it make the tire fall off? The wheel bearing being bad that is.
Apr 20, 2016 at 6:07 AM
HMAC300
  • 48,601 POSTS
if it's wobbling it's dangerous to drive. it will damage brakes as well as possibly a strut or other suspension components.
Apr 20, 2016 at 8:22 AM
