Hi:
If the car has been setting for ten years, the gas in it is no good and needs to be removed. You may have to remove the carb and clean it too. Aso, when the tank is out, blow out the fuel lines and replace the fuel filter. Then replace the gas. Otherwise you're going to have a really hard time starting it.
I hope this helps.
SPONSORED LINKS
Tuesday, November 18th, 2008 AT 10:43 AM
