2003 Cadillac DTS Struts
12,500 MILES • V8 • 2WD • AUTOMATIC
FSMDOUG
A mechanic diagnosed that in order to correct the rumble coming from the front passenger side, I needed to replace both electronic struts at a cost of $2,000.00 installed. Can the passenger side electronic strut be repaired or is the replacment of both driver and passenger side required?
Sep 16, 2009 at 1:34 PM
FACTORYJACK
  • 4,159 POSTS
When does this rumble occur, while turning the steering wheel? To answer your question, you do not have to replace both at the same time, and the strut itself is non-repairable.
Sep 17, 2009 at 3:26 PM
FSMDOUG
The rumble sound does not occur while turning the steering wheel. It occurs while driving over a rough surface
Sep 17, 2009 at 10:33 PM
