2000 Cadillac DTS
JERRY3RD
  • 2000 CADILLAC DEVILLE DTS
  • V8
  • 4WD
  • 142,160 MILES
MY CADILLAC DTS STABILITY LIGHT IS ON ALSO MY SUSPENTION LIGHT IS ON AND WHEN IM DRIVING AT ANY GIVIN MIUNTE IT WILL SLOW IT SELF DOWN UNBENOUNCED TO ME AS IF I WAS IN A MANUAL STICK SHIFTING THE CAR TO STOP WITH OUT USING THE BRAKES THIS IS MY FIRST TIME SO ILL TAKE A FREEBIE ON THIS TO SEE IF ITS REAL OR NOT
Tuesday, February 2nd, 2010 AT 11:36 AM
FACTORYJACK
  • 4,159 POSTS
Press info up, and on/off on your instrument panel, after a brief segment check you should see ALL? Press on/off again, and you should see ALL CODES? On the info center. Press on/off again and record the codes. Initially, the one for the stability message will be an ABS code Cxxx.
Wednesday, February 3rd, 2010 AT 12:01 AM
