Blower Motor Replacement
2 LINSEY
  • 287 POSTS
Have you had any luck getting the blower motor on your cadd fixed?
Thursday, November 29th, 2018 AT 7:36 PM (Merged)
BUDGIN
  • 6 POSTS
No, never could get it out.
2 LINSEY
  • 287 POSTS
Sorry to hear you were unable to remove your blower motor. Let us know if you have any other questions.
DWILBU02
I have the same problem. Can not get the blower housing to drop low enoufg tp come out. The rubber backing and the firewall will not allow me to turn on drop the housing enough to come out. What a drag. I've unscrewed a lot of hard to get scnd up this wayrews and unpluged too many cables to end up unable to remove the blower. Going to be embarassed taking the car to the dealer this way. Hope they don't charge me more money.
TOM MICHAEL
Yes, it was a major PITA but I got it out and the new one in. Only have to remove the silencer panel but I pulled glove box as well. The trick was I had to cut some of the rubber insulation away on the back end. I used a utility knife. That is where it was hanging up. Once I did that I was able to squeeze it into place. The screw in the back is a pain as well. New one on amazon was $75.00. Plan on spending a good hour or two and a sore back afterwards.
Wednesday, March 3rd, 2021 AT 7:48 AM
KEN L
  • MASTER CERTIFIED MECHANIC
  • 47,643 POSTS
Excellent addition to this thread! Please feel free to use 2CarPros anytime!
Friday, March 5th, 2021 AT 8:47 PM
CLAYTON TISTLE
2001 Deville, I have the original blower motor out but can’t figure out the angle to get the new one in. Anyone have any advice?
Wednesday, August 18th, 2021 AT 2:59 PM
  • 52,797 POSTS
Good morning,
As stated in previous responses, I would pull back the carpet and the insulation on the floor. That should give you enough room to install the motor housing.
Friday, August 20th, 2021 AT 11:32 PM
