2002 Cadillac Deville
2002 CADILLAC DEVILLE
135,000 MILES • V8 • FWD • AUTOMATIC
DEAFMANOK
My cars stalls about once a week.... BUT only at stop lights or stop signs. I suspect the idle control valve is unstable... or the throttle postion sensor is acting up. How can I tell which it might be. I did clean the throttle body and still stalls. NOTE: once it stalls it is a bit hard to start unless I press on the gas just a little. Then when it starts, it is not a problem for another week. Also it only stalls shortly after starting the car on the morning OR when i start the car and go home and it ALWAYS stalls at stoplights in LESS THAN 5 mins. It never stalls when the engine is hot ( say running over 10 minutes). MANY THANKS !
Sep 22, 2010 at 1:24 AM
WRENCHTECH
  • 20,761 POSTS
The intermittent nature of the failure is going to make it very hard to confirm anything. Even with a high grade scan tool, it would be hard to spot a glitch that rare. I would suggest changing the IAC as that is likely the problem.
Sep 22, 2010 at 2:31 AM
