1994 Cadillac Deville Brake lights
105,000 MILES • V8 • 2WD • AUTOMATIC
TRYWINE
My turn signals work. My hazard lights work. When I press the brake pedal the passenger and third brake lights illuminate. The drivers light goes out. All bulbs work normally except when braking. Any ideas? Thanks.
Dec 17, 2008 at 11:05 AM
  • 110,248 POSTS
Hi:
There is a ground problem to the bulb. I would first try replacing the socket to see if that fixex the problem. If is has a circuit board set-up, it may need replaced. Also, make sure the ground to the bulb is clean and tight.
Dec 18, 2008 at 5:46 AM
