I am a little misunderstood of your terminology, particularily 'locking' and 'pulses'. You say you have a code for electrical pulses, what is the code number? That may provide me a clearer understanding of what you are describing. You mention you get a release feeling, and I can only imagine misfires under load, that as you ease the pedal decreasing the load, it stops misfiring and running smooth. That kind of feels like what can be described as a release. If someone can show you the coil packs, and the secondary terminals are corroded, then yes you should have them replaced, they can be causing misfires. Also the plug wires are corroded as well, on that end. A clogged converter will not give you an intermittent fault. Sometimes they can be a bit unnoticed at lower rpms, but as exhaust pressure is increased, the loose particles get to moving around and can clog. Often once they are lifted off the bottom of the cat, exhaust pressure keeps them there.
SPONSORED LINKS
Monday, October 4th, 2010 AT 11:21 PM
