1999 Cadillac Deville fuel pump failure
JOSEPH REST
  • 1999 CADILLAC DEVILLE
Engine Performance problem
1999 Cadillac Deville V8 Front Wheel Drive Automatic
Can the fuel pump fail if the car is attempted to start on an empty tank (4 attempts, 20 sec between them)?
Sunday, May 30th, 2010 AT 8:27 AM
BLUELIGHTNIN6
  • 16,542 POSTS
It's possible it could burn up, yes. If you ran out of fuel and have trouble starting it back after refueling then most likely the fuel filter is clogged and also the fuel system needs primed. To prime it, turn the key to ON position without cranking, then back to off. Do that several times to prime. If still won't start then replace fuel filter
Monday, May 31st, 2010 AT 1:20 AM
