1999 Cadillac Deville fuel line
ERIC702
Electrical problem
1999 Cadillac Deville 6 cyl All Wheel Drive Automatic
ran out of gas, put more gas in, and will still not start. What do I do?
Nov 17, 2008 at 3:36 AM
  • 110,248 POSTS
Hi:
A couple things may have happened. First disconnect the fuel filter and check if it's clooged. If not, you'll need to check if the fuel pump still works. Sometimes the when the tank gets that low, there could be dirt the pump picks up causing problems.
Let me know if you have any other questions.
Nov 17, 2008 at 10:00 AM
