1994 Cadillac Deville
BDEEZY25
Electrical problem
1994 Cadillac Deville 6 cyl Wheel Drive Type unknown Manual 237,46 miles
ran out of gas filled it up and want start could it be the fuel pump
Feb 28, 2008 at 12:08 AM
CHISPAS
  • 20 POSTS
I'm not a mechanic but have similar problems with electric fuel pumps, they are difficult to start once you go on empty, I think they need time to prime. Try using some quick start fluid on the carb it worked for me.
Like I said I'm not a mechanic but that's a start.
Good luck.
Feb 29, 2008 at 11:08 AM
BUZZSAW
  • 1,198 POSTS
[quote:4378df539f="Chispas"]I'm not a mechanic but have similar problems with electric fuel pumps, they are difficult to start once you go on empty, I think they need time to prime. Try using some quick start fluid on the carb it worked for me.
Good luck.[/quote:4378df539f]
carb? cars dont have carbs anymore, but do try to prime the throttle with carb cleaner not starting fluid
Mar 5, 2008 at 1:10 AM
