alternator wiring diagram - batter not charging?
AFRO2
the battery not charging message came on. i turned the ignition off and car will not start when i tried to turn it on again.
Jun 14, 2008 at 3:24 PM
LEGITIMATE007
  • 5,121 POSTS
It sounds like the alternator went bad but to be sure let's jump the battery and check the alternator here are two guides to help us get started.
https://www.2carpros.com/articles/how-to-jump-start-car-battery-using-jumper-cables
and
Jun 14, 2008 at 3:34 PM
MYMATTHEW33
Replace the alternator, all fixed!
Feb 12, 2019 at 6:00 AM
99CADDY
For about two months my car's computer has been showing intermittently that the battery was not charging. It would be fine for days then for a few minutes the message would come up on my screen.
It has progressed now to the point that it is on steady and today the power level must have gone down significantly as power systems started shutting down.
The battery is new as I bought it 6 weeks ago so I am guessing by these signals that the problem may be the alternator.
What am I faced with if I decide to replace the alternator myself.
Feb 12, 2019 at 6:01 AM (Merged)
CHISPAS
  • 20 POSTS
You should check the alternator first before you replace it, most auto parts stores will do this free of charge.
Unless the car gurus at 2 Cars Pros have a different advise.
ED ARMES
  • 129 POSTS
Recheck the battery. The cables may not be tight enough to provide good contact.
BUZZSAW
  • 1,198 POSTS
[quote:d467bf0391="99Caddy"]Electrical problem
1999 Cadillac Deville V8 Front Wheel Drive Automatic 110000 miles
What am I faced with if I decide to replace the alternator myself.[/quote:d467bf0391]
it is kinda hard to do, the alt comes out the bottom of the car, and dont puncture the radiator
ED ARMES
  • 129 POSTS
Assuming you have the 4.6 Engine mounted side to side.
When you get to the step of removeing the wires and ground strap, be sure you check if they are just loose. It coul eliminate alot of work.
1. Disconnect negative battery terminal.
2. Drain engine coolant.
3. Remove cooling fans and radiator.
4. Remove serpintine belt.
5. Raise the front on jack stands.
6. Remove lower splash guard.
7. Disconnect coolant outlet and inlet hoses from under side of alternator if yours has them.
"Check wiring now."
8. Remove battery cable from starter.
9. Remove ground strap and 3 upper alternator bolts.
10. Remove hose bracket.
11. Remove lower alternator bolt and drop unit out of car.
USER NOTE: You dont need to do all that!! There is a small plate that you unbolt under the radiator and you have all the clearance you need. There is NOTHING hard about this. Just watch out for your radiator.
BUZZSAW
  • 1,198 POSTS
Excellent addition to this thread! Please feel free to use 2CarPros anytime!
ED ARMES
  • 129 POSTS
Our job is to assist a layman in the task at hand. It might take him 5 days in his spare time. He is certainly not getting paid to work on his own vehicle.
It is your job to give as complete instruction as possible for the successful completion of the repair.
Given the information we provide, the "client " can make up his own mind wether to repair it himself or pay "you" to do it.
Our job is to give insight and lots of detail. That is what you signed on and agreed to as a moderator so just do it.
LEOKARTXIV
Electrical problem V8 Front Wheel Drive Automatic 140000 miles
I have a 99 Cadillac Deville and I am having some charging system issues. This all started right after I had the Ignition Cylinder replaced as i had a theft system light come on and i was told that one of the wires to the cylinder had broke and was causing this prompt. Anyway after that I was driving the car and the theft light came on again for a second then the traction control light came on. I shut the car off when I got to where I was going and everything was fine. a few days later it happened again but this time I noticed that i was having difficulty starting the car. I checked the battery and it was 3 yrs old so I replaced it. I drove it around for a few minutes and the theft light came back on the dash lights started flashing and the volt guage on the car showed 11.7 volts. I then figured it was the alternator or a ground. I replaced the alternator and I have checked and cleaned all the grounds. now when I start the car it starts out at around 14 volts but the longer I drive it, it starts dropping off. and as soon as it gets down to 12.3 volts the dash lights start going off again. I drove it around a little more and the voltage came back up to around 13.6 volts. I am at a loss for what else to check any help will be apprecieated thanks.
BUZZSAW
  • 1,198 POSTS
it sounds like you have an alternator diode that is out.
STEVE W.
  • 15,409 POSTS
Sounds like you have a very large parasitic draw. If this only occurred after the ignition cylinder was replaced I would start with a visual inspection of the wiring harness and see if it is pinched or shorted under the dash where the work was done.
If the battery itself was disconnected during the repair it is also possible that there is a bad connection there and the voltage drop is due to a bad cable. GM cables are bad for corroding inside the housings for the battery terminals.
ED ARMES
  • 129 POSTS
If you truly cared about the client then your first and only response should have been " I have an easier way to do this" and then told him how and not let your ego out weigh your knowledge!
CHISPAS
  • 20 POSTS
Well said Ed.
I'm not a mechanic just a regular Joe, but if something worked for me in a particular problem I'm more than happy to share it. that's what this forum is all about .
I posted a simple question about my trany cooling lines about 2 months ago so far no answer.
I sure hope the Tech's in this forum go back to do what they pledge to do and leave the ego trips at home.
MUNDENJA
you answered my question to check out the above, but seems no one knows how to check them. Right now we simply unplug the blower when we stop, and plug it back in. this tells me you are probably right, everyone want to change out the module, no one seems to know how to check the relays or sensor. Do you know someone that would not charge an arm and leg to check out.
How much should it cost for us to get this fixed?
ED ARMES
  • 129 POSTS
Thank you for your support of me in this matter. I shall always be in support of the regular Joe wether I am paid or not. I will see if I can find your question and see if I can help.
BLUELIGHTNIN6
  • 16,542 POSTS
hello
not really sure which relay you're talking about, i'm guessing the blower motor relay? follow the link below to learn how to test an electrical relay..
https://www.2carpros.com/how_to/how_do_i_check_a_relay.htm
CHISPAS
  • 20 POSTS
Back to the original question.
Is it an easier way to replace the alternator other than the one Ed suggested ?
Does the Caddy book shows you how or only quote's how long the dealer take's to do the job.
BUZZSAW
  • 1,198 POSTS
[quote:0a9e1451bd="Chispas"]Back to the original question.
Does the Caddy book shows you how or only quote's how long the dealer take's to do the job.[/quote:0a9e1451bd]
it pays an hr to 2, disconnect the battery, jack the car up in the air, put jack stands under the driver and pass doors, you need to drop the craddle in the front, remove the wires to the blower motor, dropping the frt of the craddle will pull it apart, remove the plastic splash guard and then with a jack put it under the craddle, remove the 2 frt craddle bolts and lower the craddle, it wont go far, but enough. remove the fan relays this is where the alt will come out and remove the small plate
its much easier with a lift
CHISPAS
  • 20 POSTS
MAX 34
I just put a brand new alternator on and it's saying it's not charging What could be the problem
CARADIODOC
  • 34,414 POSTS
Why did you replace the generator? Is the battery more than two years old?
JSANDERS21
im having problems with my service charging system and my battery keeps dieing
SATURNTECH9
  • 30,869 POSTS
Have you had your alternator and battery tested yet?
JSANDERS21
yes and they told me that they both were good
SATURNTECH9
  • 30,869 POSTS
So is the service charging system light always on?
CARGUY13
alt will not charge when first started but in 5 to 10 mins. works fine 14.3v and works good all day. Battery test good . But battery needs replacing about very 6 months car not driving far or much. alt test good when working.
HMAC300
  • 48,601 POSTS
check battery for condition including load test then make sure terminals are clean as well at engine and body like the grounds. check fusible link to alternator it may only have a few strands connected causing your problem.
MS. PAMELA H.G. GUNCHICK
Hi
Please reply with any and all answers and or advice.
I bought a used 1998 Cadillac sedan deville with 62000 miles on it
The original one previous owner had kept all original records etc. She took it to the dealer all the time.
Now i come along and buy it.
She replaced the battery in august 2008 i bought the car in October 2008 now here in may 2009 i put only 2000 miles on it in 7 months. Now i get the ""battery not charging light" on the battery cost jean the original owner $150.00 dollars and it is less than 1 year old?
What does this light refer to?
Please reply
Thanks so much!!
God bless
Sincerely
Pam
THIS IS MIKE
  • 686 POSTS
The "BATTERY NOT CHARGING LIGHT" refers to a problem with the charging system. It could mean that the alternator is not charging properly. You should have both the battery and the alternator tested to make sure the alternator is putting out the proper charge and the battery is able to receive and hold a full charge. Also make sure the battery cables are tight.
MICHAEL0001
we have replaced a battery, alternator. gave it a jump start and ran it for a bit.to find the air cond. running and unable to shut off.then to dissconnect the jumper cables , shut off the car, it goes back dead,nothing. seond time of jump start,now there is no clicks of the starter.
DOCFIXIT
  • 18,828 POSTS
Check battery cables POS to starter and NEG to block.
JACKPELT
car does not charge battery have had alternator replaced still have problem dash shows system not charging drains battery and dies some times message goes off car runs ok for a little while . have had car checked at a mechanic could not find problem. dont trust car any more so dont drive it.any suggestions?
HMAC300
  • 48,601 POSTS
it can be a connection proble from pcm and or alternator so would need to be checked for that.
Feb 12, 2019 at 6:02 AM (Merged)
2CP-ARCHIVES
  • 4,540 POSTS
have the alternator checked as it may have failed
CHRISTIE HOWE
replace alternator help.
HMAC300
  • 48,601 POSTS
see pictures. you do not need to remove radiator like instructions say. alternator comes out through bottom, you may have to take a shield off however.
PAPA2593
old alternator died and replaced it with a new one but now it does not charge. traced it down to no voltage going to the regulator
Feb 12, 2019 at 6:03 AM (Merged)
WRENCHTECH
  • 20,760 POSTS
So, apparently the alternator wasn't the problem. That power is supplied by the PCM but my diagrams don't show where the PCM gets it from. I would use a test light and test every fuse with the key on. https://www.2carpros.com/images/external/81022107.jpg.gif
