1998 Cadillac Deville white exaust smoke
103 MILES • V8 • FWD • AUTOMATIC
CADDYLADY71
after starting the car smokes profusely, every few weeks car is asking for coolant
Apr 7, 2008 at 4:53 AM
CADILLAC MAN
I have the same problem only to less of an extent. I was told that the problem was a mixture of oil and carbon on my 97 seville (cadillac has a soloution to cleen it), But since it is asking for coolant, anti - freeze may be entering your block some how. It may be an intake maniflod or blown head gasket. The best way to tell if its a head gasket is if there is anti - freeze in the oil... You can also get a dye test done on it to tell if its a blown head gasket.
Apr 7, 2008 at 8:57 AM
BUZZSAW
  • 1,198 POSTS
[quote:c807ed32a6="Cadillac Man"]I have the same problem only to less of an extent. I was told that the problem was a mixture of oil and carbon on my 97 seville (cadillac has a soloution to cleen it), But since it is asking for coolant, anti - freeze may be entering your block some how. It may be an intake maniflod or blown head gasket. The best way to tell if its a head gasket is if there is anti - freeze in the oil... You can also get a dye test done on it to tell if its a blown head gasket.[/quote:c807ed32a6]
this year doesnt have coolant running through the intake ( 89-93 ), have your cooling sys pressure tested, never seen a headgasket leak before, like that. you may have other leaks for the coolant, usually white smoke is actually blue so it oil burning and carbon. headgaskets usually just make it overheat as long as waterpump and belt, radiator, thermostat, and cooling fans are working fine
Apr 10, 2008 at 10:27 PM
BASSMUSICIAN
  • 38 POSTS
I just bought a 1999 DeVille in January. I believe mine may have sit a long time without being driven, and when I bought it, well just before I bought it, they changed the water pump and put a new Thermostat in it, and they failed to add the Pellets that Caddilac adds to the Northstar, plus they put the Green antifreeze in it, not the red that Caddilac demands. (GM Duramax, or other silicate free) it had a little white smoke, but went away after the car warmed up. Well on the advise of a friend who works for GM and used to build the larger Buicks, I added the Pellets. (Its actually those Bars Stop Leak Pellets, these cars come from the factory NEW with stop leak pellets!
Mine stopped smoking, stopped backfiring and stopped fouling plugs. I've put around 2000 miles on it since doing that. Sounds like yours is alot worse than mine though. I'd take it to the Cadillac dealer, I've found other mechanics dont even like to look at these cars. Good Luck! Jack
Apr 13, 2008 at 4:14 AM
BUZZSAW
  • 1,198 POSTS
[quote:5c6adf976f="Bassmusician"]I just bought a 1999 DeVille in January. I believe mine may have sit a long time without being driven, and when I bought it, well just before I bought it, they changed the water pump and put a new Thermostat in it, and they failed to add the Pellets that Caddilac adds to the Northstar, plus they put the Green antifreeze in it, not the red that Caddilac demands. (GM Duramax, or other silicate free) it had a little white smoke, but went away after the car warmed up. Well on the advise of a friend who works for GM and used to build the larger Buicks, I added the Pellets. (Its actually those Bars Stop Leak Pellets, these cars come from the factory NEW with stop leak pellets!
Mine stopped smoking, stopped backfiring and stopped fouling plugs. I've put around 2000 miles on it since doing that. Sounds like yours is alot worse than mine though. I'd take it to the Cadillac dealer, I've found other mechanics dont even like to look at these cars. Good Luck! Jack[/quote:5c6adf976f]
I always threw them away, they dont disulve like there supposed too, they clogg up the overflow tank and heater core
Apr 15, 2008 at 6:09 AM
