1998 Cadillac Deville 98 Deville Overheating ..PCM Code P03
1998 CADILLAC DEVILLE
79,000 MILES • V8 • AUTOMATIC
LAOBOI
My 98 Deville is starting to overheat and loose coolant as well. I am sure it is the head gasket because my car symptoms are similar to others who have experienced head gasket difficulties. Would this problem resurface if the timeserts are installed at a Cadillac dealership? I also have an oil leak, which I think is associated with the head gasket problem. Would a bad head gasket make the Northstar leak oil as well? I had a 98 Dodge Neon and the head gasket was bad on it and it leaked oil as well. After the Neon head gasket was repaired, it stopped leaking oil. My car only has 79,000 miles on it, so I think it is worth the repair. Does the transmission usually fail after the head gasket goes bad?
Do you have any advice on what I should do?
Jan 10, 2010 at 4:06 PM
FACTORYJACK
  • 4,159 POSTS
Are you saying that the timeserts have been installed? I have not seen one repeat failure after thread inserts. If it leaks oil from heads, it is usually in the intake valley. There is no similarity of transmission failure after head gasket failure.
Jan 11, 2010 at 6:01 PM
LAOBOI
You answered my question. I basically wanted to know if headgasket failure occurs after the timeserts are installed. I have not had the timeserts installed yet, but I will have them installed shortly.
I am not sure where the oil leak is coming from, it does not leak a lot of oil, but there is a stain in the driveway each time i drive it.
I did not know the Northstar was so much trouble. The car is 12 years old, but it only has 79K. The car has been pampered, therefore I guess the headgasket failure is a design flaw steming from Cadillac Motor Division.
I am willing to spend $3500.00 to have it fixed, however if it is more than $3500.00 I guess I will look for another Cadillac.
Jan 12, 2010 at 12:29 AM
FACTORYJACK
  • 4,159 POSTS
Chances are, and I am giving you worst case, that the lower crankcase is leaking.
Jan 12, 2010 at 2:53 AM
