1996 Cadillac Deville
BRE4SHO
1996 Cadillac Deville 6 cyl
MY CADILLAC DEVILLE WILL NOT START I HAVE REPLACED THE STARTER AND THE BATTERY. COULD IT BE THE FUEL PUMP?
Sep 2, 2010 at 11:54 AM
FACTORYJACK
  • 4,159 POSTS
It could be the fuel pump if it is cranking and not starting. You can tell if it is a fuel problem if you spray starter fluid in the throttle, crank it and it fires but dies shortly after. This does not necessarily mean a pump is bad, but there is a probability. If it is not cranking, you have other issues preventing the starter from engaging.
Sep 2, 2010 at 1:42 PM
