1996 Cadillac Deville car won't start
70,000 MILES • V8 • FWD • AUTOMATIC
MARYDUNBAR
I have a 1996 Cadillac (northstar) that I just bought a new battery for but it won't start.It cranks up like it won't to start but won't...Any suggestions...Thanks...Mary
Aug 27, 2009 at 12:24 PM
  • 75,988 POSTS
Check if its fuel or spark problem
Get a starting fluid/ether/better off gas in a spray bottle and spray into the carb or the throttle body on an EFI. Did it start and die? If not disconnect a sparkplug wire or 2 and ground it to the engine -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs,coil's resistances,cap and rotor /distributor pick-up coil, ignition control module, ECM,Ignitor cam and crank sensors- Note: If it doesn't apply disregard it
Aug 27, 2009 at 12:47 PM
