1996 Cadillac Deville
MOAGLY
Electrical problem
1996 Cadillac Deville V12 Front Wheel Drive Automatic
my daughters car wont start turn key and just one click and thats it got a new battery.
Jun 15, 2009 at 2:21 PM
FACTORYJACK
  • 4,159 POSTS
If the connections are clean, tight, and corrosion free, then check for signal to the starter by disconnecting the two wire connector at the front of the rear bank valve cover and checking for 12 volts, or a test light to light when in crank position. The signal wire is large purple wire, and make sure you are at harness side, not the starter side. If it has a double connector end on the positive post, there should be a lead spacer in between. If it is not there the starter will in most cases, not engage.
Jun 15, 2009 at 2:32 PM
MOAGLY
could it be a fuse
Jun 15, 2009 at 2:46 PM
FACTORYJACK
  • 4,159 POSTS
It could be a fuse, it could be a park/neutral switch, ignition switch, starter, several things. If you can verify whether or not a signal is getting to the starter, we can eliminate all except the starter. You said it clicks, does it click once, each time the crank position is engaged? Does it make several rapid clicks at that time, almost a buzz. What do the lights and accessories do at that time?
Jun 15, 2009 at 2:54 PM
MOAGLY
just one click
Jun 15, 2009 at 3:02 PM
MOAGLY
all lites work insterment pannel lights up lt just one click and notin else
Jun 15, 2009 at 3:05 PM
FACTORYJACK
  • 4,159 POSTS
Does the click come from under the hood, once every time crank is reached? It sounds like a starter to me, but that is based on our discussion.
Jun 15, 2009 at 5:57 PM
