I get back in the car, turn the key and nothing happens, no clicks or anything?
137,000 MILES • V8 • FWD • AUTOMATIC
JOSH515
Hi, I drove my car up the street and turned it off like usual. I get back in the car, turn the key and nothing happens, no clicks or anything like when your battery is low. I thought it was probably the starter so I replaced it and still the same thing, nothing. It seems like no power is getting to the starter from the key switch. So then I turned the ignition on and shorted out the cellanoid and the starter does turn the motor but it won't fire. Please help me. Thank You.
May 31, 2009 at 11:08 AM
  • 75,988 POSTS
If you can get the starter to crank the engine by shorting out the solenoid and will not start. Test the ignition switch might not be powering the ignition system
May 31, 2009 at 12:15 PM
FACTORYJACK
  • 4,159 POSTS
What does the 'security' telltale light do? If it stays on solid while key is on, it is telling you you have a theft problem. More that likely the ignition cylinder leads are open. At the large connector at the base of the column there is two small wires in an orange sleeve. You can measure the resistance across these two wires(disconnected), in all ranges of ignition switch(run,crank). Sometimes you will have continuity in one range and not another. If it is open circuit at crank, it will not crank. Ideally, if you can measure the resistance of the key pellet, you will get the desired result that should be seen at the base connection.
Jun 1, 2009 at 3:34 PM
