Check for disconnected battery (red cable) to the starter.
If the cable is tight and clean,
Check for a disconnected purple wire at the starter. If the purple wire is good,
Check starter relay, located front seating area, passenger side, under dash, mounted behind glove compartment cavity.
If changing the relay does not change the problem, the starter is bad.
Check your email for the diagram
Saturday, December 26th, 2009 AT 12:48 AM
