1984 Cadillac Deville Hesitates
HOCKEYMAN340
i have a 1984 cadillac sedan deville with the 4.1 motor. it has 82,xxx miles. it hesitates when i begin to accelerate. once i get past the initial hesitation it runs great. threw a throttle position sensor code so i replaced it. it still hesitates. i dont want to just throw parts at it and i don't know much about cadillacs. can you help? thanks
Feb 16, 2007 at 3:17 PM
MARYANN340
i sent a donation to help aid with my issue with the car but still no response. so much for buying help. thanks
Mar 9, 2007 at 2:34 PM
MERLIN2021
  • 17,250 POSTS
if your still checking, I don't normally cruise Caddy, but if you got a TPS code then I would guess the throttle shaft is worn...
Mar 27, 2007 at 8:38 AM
Suggested Repair
Inspect the throttle shaft for wear. A throttle position sensor code that remains after sensor replacement can indicate a worn throttle shaft affecting sensor operation.
Conversation Summary
The owner of a 1984 Cadillac Sedan Deville with a 4.1 engine and about 82,000 miles reported hesitation when first accelerating, after which the car ran well. Replacing the throttle position sensor after a related code did not fix it. An expert suggested the throttle shaft may be worn.
