1989 Cadillac Deville Rough Running
Cly
Cly
Suggested Repair
While the rough running is occurring, check the fuel injectors by measuring resistance, wiggling their wiring, and lightly tapping them. Also inspect for intermittent wiring or grounds and test the engine control module. A fuel pump is unlikely to cause the over-fueling.
Conversation Summary
A 1989 Cadillac Deville with a V8 shakes badly, smells through the vents, needs full throttle to move, stalls when the throttle is released, and sometimes returns to normal after a bump. It also uses excessive fuel, about 8-10 mpg, during the rough phase. Tune-up parts, the MAF, air and fuel filters, temperature sensor, oxygen sensor, and catalytic converter were already replaced. The expert suggested intermittent wiring, a ground, or the engine control module, then later pointed to failing injectors rather than the fuel pump and recommended testing the injectors while the problem is present.
