1997 Cadillac DeVille Head Gasket
R. FEHR
  • 10 POSTS
Looking at a "perfect car needs head gasket" for less than $1k. (97 Cadillac Sedan Deville 85000 miles) I do all my own work, but would like to know before I start what is the flat rate hours for this? I usually take about 3 times as long. Does it make sense to replace both head gaskets at the same time? Plus, any other things to look out for either before or after purchase? And third, is there a better choice for a new head gasket than the standard Fel-Pro?
Thanks,
R.
Jul 12, 2006 at 8:11 AM
R. FEHR
  • 10 POSTS
Since I posted I contacted a GM tech and he sent me portions of service manual instructions. First step is to remove engine from car. This makes replacing both gaskets and using new head bolts easier. It also makes rethreading the cylinder head bolt holes easier to do right.
Any other feedback?
Thanks,
R.
Jul 14, 2006 at 1:51 AM
BGLOCC
How do you know if your head gasket needs to be replaced?
Dec 20, 2007 at 4:13 AM
BUZZSAW
  • 1,198 POSTS
[quote:b79eea1f0b="R. Fehr"]Since I posted I contacted a GM tech and he sent me portions of service manual instructions. First step is to remove engine from car. This makes replacing both gaskets and using new head bolts easier. It also makes rethreading the cylinder head bolt holes easier to do right.
Any other feedback?
Thanks,
R.[/quote:b79eea1f0b]
drop the craddle and the motor and trany come down as a unit, if you were overheating, the threads in the block need fixing, get the heli coils from the dealer. you will also need the drill bit for it, the bolts are the problem, not the gasket, this is caused by the overheating
Dec 20, 2007 at 9:09 AM
Suggested Repair
Drop the cradle so the engine and transmission come out as a unit. If the engine overheated, repair the cylinder-head bolt threads in the block with dealer heli-coils and the correct drill bit; the bolts, not the gasket, are the usual failure. Replace both head gaskets and use new head bolts while the engine is out.
Conversation Summary
The owner is considering a 1997 Cadillac DeVille with 85,000 miles that reportedly needs a head gasket and asked about labor time, doing both gaskets, and gasket brand. A GM tech said the engine must be removed. The expert advised dropping the cradle so the engine and transmission come down together, and said overheating damages the block threads, so dealer heli-coils are needed because the bolts are the problem rather than the gasket.
