1982 Cadillac Deville car wont start
4,447 MILES • V8 • 2WD • AUTOMATIC
BOBBYBILLZ
  • 5 POSTS
i have a 1982 cadillac deville with a 4.1 liter v8 (4100 D.F.I.). I replaced the fuel filter, fuel pump, the 2 injectors and inspected all my fuses and fuel lines. the car will crank but it wont run unless i spray starter fluid into the throttle body. My fuel is being restricted somehow. what could it be?????
Oct 15, 2009 at 12:56 PM
FACTORYJACK
  • 4,159 POSTS
Have you determined that you are missing either fuel pressure, or injector pulse?
Oct 15, 2009 at 3:19 PM
BOBBYBILLZ
  • 5 POSTS
how do i check for pressure or injector pulse? and if its either of those, what would be the source?
Oct 15, 2009 at 4:39 PM
THIS IS MIKE
  • 686 POSTS
Here is a link that shows how to test your fuel system
https://www.2carpros.com/how_to/how_to_check_fuel_pressure.htm
Oct 16, 2009 at 6:17 AM
FACTORYJACK
  • 4,159 POSTS
You should have a test port in the lines heading to the throttle body, and it probably has a spin-on cap on it. Ideally, you would need a pressure gauge, for relatively low pressure, throttle body systems generally run 13-15 psi. As far as injector pulse, you would need an item called a noid light, or a high impedence powered test light. A general 12v test light wont work, and could damage the driver in the ECM. Disconnect an injector, plug the noid light into the connector, and crank. Light flash=pulse.
Oct 16, 2009 at 3:09 PM
BOBBYBILLZ
  • 5 POSTS
ok, i tested the injectors and the fuel pressure. the injectors are fine, but my fuel pump isn't working. I tested the fuel pump and it works, im just not getting power to it from the harness. how can i isolate the problem???? what could it be thats not working, the ecm, a bad wire maybe?????
Oct 18, 2009 at 4:03 PM
2CARPRO JACK
  • 11,533 POSTS
Check the fuel pump relay to see if it clicks when you crank the engine.It is located in position 8 under the dash in the relay center
Oct 19, 2009 at 9:56 AM
BOBBYBILLZ
  • 5 POSTS
the relay clicks once and i also tested the injectors a second time and the injector grounds are not working. the first time i tested them, i used the frame ground. I am also getting power to the fuel pump after i tested it again and again. i get between 9-11 psi fuel pressure to the throttle body, but my injectors wont spray, are there any other tests i can do or do you know what this could be????
Oct 19, 2009 at 12:20 PM
2CARPRO JACK
  • 11,533 POSTS
So you have power to one side of theinjector plug? If so you may have lost the injector driver in the ECM. Since you have spark, the ECM is most likely getting the signal that the engine is turning, but it doesnt have the driver to trigger the injector (ground triggered). you can do a continuity test from the injector plug to the ECM, but I have a feeling it will be ok, and that the ECM is at fault.Good news is that those ECM's are very inexpensive and dont require programming, they are basically plug-and-play
Oct 20, 2009 at 12:43 AM
BOBBYBILLZ
  • 5 POSTS
i got a new ECM and the problem still exists, my guess is that somewhere between the injectors and the ECM I have a bad ground wire or a broken ground wire. How can I check or test the ground from the ECM to the injectors?
Oct 20, 2009 at 1:35 PM
