Car will not start
SREVE
  • 1999 CADILLAC DEVILLE
  • 4.8L
  • V8
  • 136,000 MILES
Car won't start theft system problem light is on and fuel pump relay clicks constantly when key is on.
Saturday, February 27th, 2016 AT 2:13 PM
KEN L
  • MASTER CERTIFIED MECHANIC
  • 50,088 POSTS
The car will do that if the battery is low can you check it, here is a guide.
https://www.2carpros.com/articles/how-to-check-a-car-battery
please let us know what you find so it will help others
Thursday, June 6th, 2019 AT 3:21 PM
SREVE
  • 6 POSTS
I bought a new battery and still the same problem. Left key on to reset computer but still won't start. Will turn over but not start. Fuel pump relay still clicking constantly.
KEN L
  • 50,088 POSTS
It sounds like the fuel pump relay or the fuel pump has shorted, try the relay first here is a video on how to replace it.
https://www.youtube.com/watch?v=S6ka-fscAuw
Please get back to me
SREVE
  • 6 POSTS
I tested the relay and it's ok. I checked the voltage going to relay and it is sporadic. I think the car won't start has something to do with the theft system problem. The theft system problem light is still lit up on dash.
KEN L
  • 50,088 POSTS
Okay, open the open and close all doors, disconnect the battery for two minutes and reconnect, Then lock and unlock the drivers door and then try to start the car, please let me know what happens
SREVE
  • 6 POSTS
Ok, I'll try that tomorrow. Will let you know tomorrow night. Thanks for your input.
SREVE
  • 6 POSTS
I tried opening and closing doors, disconnected battery for 2 minutes, reconnect, lock and unlock drivers door, and still no change.
KEN L
  • 50,088 POSTS
Those cars have little wires coming out of the ignition switch which lead to the security system, its sounds like one of them is broken, you will need to remove the ignition tumbler to see if this is the problem.
SREVE
  • 6 POSTS
I did read that somewhere. Can I bypass that with some resistors?
KEN L
  • 50,088 POSTS
I don't think so the security system must be enabled and that's the only way I know of though I have heard of people bypassing it somehow, if you learn how please let me know
