1973 Cadillac Deville Ventilation
62,800 MILES • V8 • 2WD • AUTOMATIC
BBABINEAU
The air conditioner does not work but when I run the heat or defrost it initially fogs the windows and it takes at least a half hour of operation before the windows clear. There is also a smell of antifreeze in the car when the defrost is blowing.
Oct 27, 2009 at 8:59 AM
RACEFAN966
  • 5,029 POSTS
Ok so do loose antifreeze in the radiator too. It sounds like you have a heater core leaking. Is the passanger floor wet too?
Oct 28, 2009 at 3:26 AM
BBABINEAU
I have not noticed either the passenger floor wet or the level of antifreeze going down.
Oct 28, 2009 at 3:35 AM
BBABINEAU
Perhaps a leak has just started and not yet reached the carpet - what is an easy way to see if this is the case. How do I reach the core to have a look?
Oct 28, 2009 at 3:56 AM
RACEFAN966
  • 5,029 POSTS
Well it takes removing the top part of the dash and the glove box to get to the heater core so not an easy job. I would have it pressure tested first to see if it is holding pressure or not and take it from there.
Oct 29, 2009 at 3:26 AM
