2003 Cadillac CTS Timing Belt Change
RB0757
2003 cadillac CTS 83000 miles 3.2liter engine automatic trans, how difficult is it to change the timing belt in this car, are there any special tools needed. Any insight would be helpful
Apr 10, 2007 at 12:13 PM
SERVICE WRITER
  • 9,123 POSTS
https://images.2carpros.com/forum/automotive_pictures/30961_cad_1.jpg
Well it isn't due until 100,000 miles, and it should only take a pro about 2 1/2 hours. Difficulty level is relevant to the person doing it. If you are prepared for possible down time and have good mechanical aptitude, and are willing to except the fact that they aren't engineered for repair :evil: by the manufacturers, then try it. If your not willing to subject yourself to potential frustration or mishaps that can damage the engine, and you are aware that if you get stuck, it will REALLY get expensive to have it towed in and let someone else reconstruct the jigsaw (which techs hate) but want to try it anyways...give it a shot. You do need a scanner to clear the cold start counter before doing the job. There are a few other specialty tools reccomended:
https://images.2carpros.com/forum/automotive_pictures/30961_tool_1.jpg
Apr 10, 2007 at 12:58 PM
BUZZSAW
  • 1,198 POSTS
[quote:a1e0e7bb65="rb0757"]2003 cadillac CTS 83000 miles 3.2liter engine automatic trans, how difficult is it to change the timing belt in this car, are there any special tools needed. Any insight would be helpful[/quote:a1e0e7bb65]
it is best to do it early, if the belt breaks or you dont align it properly it will bend valves and then you will be introuble unless you have alot of money
Sep 17, 2007 at 7:59 AM
Suggested Repair
Timing belt service is due around 100,000 miles and can be done earlier as prevention. A professional job takes about 2.5 hours and requires a scan tool to clear the cold start counter plus recommended specialty tools. Incorrect timing or belt failure can bend valves, so DIY only with strong mechanical skill; otherwise have a shop perform the job.
Conversation Summary
The owner of a 2003 Cadillac CTS 3.2L with 83,000 miles asked how hard a timing belt change is and whether special tools are needed. Experts said the interval is about 100,000 miles, a pro needs roughly 2.5 hours, a scanner must clear the cold start counter, and specialty tools are recommended. Belt failure or misalignment can bend valves and become very expensive.
