2003 Cadillac CTS Car still won't start.
66,000 MILES • 6 CYL • 2WD • AUTOMATIC
INDYGAL724
Hi Rasmataz, did what you recommended. Checked fuel pressure - pressure tested OK. No signal to injectors & no spark at all. Engine turns over, but will not start at all now, not even with starting fluid. Could it be crank position sensor ? Is there a way to check CKS ohms resistance if it's off the engine ?
Nov 5, 2009 at 11:30 AM
FACTORYJACK
  • 4,159 POSTS
You can do it on, or off the engine. It is measured across pins 1 and 2, and should read 700 to 1100 ohms. Pin 1 should be white/black, and pin 2 purple/white. Pin 3 is a shield wire, and there should be no continuity from either pins 1/2 to pin 3.
Dec 16, 2018 at 1:41 AM
