2000 Cadillac Catera is a Lemon
2000 CADILLAC CATERA
CHERYLMCCORRY
I have a 2000 Cadillac Catera
My first issue was that I had a P0171 and P0174 error codes. Which
Cadillac stated was my Catalytic Converters. They replaced those
which were still under warranty along with the fuel filter which cost
me about 70.00. Then after replacing the Converters my Check Engine
light came back on and when initially starting the Car it was chugging
like it was gasping for breath or fuel. So I take it back to Cadillac
and he says the code is now a P0300 which he said has nothing to do with the Catalytic converters. He says it is misfiring do to clogged fuel injectors. So I had them run fuel injector cleaners through them twice at $120.00 per shot and also they replaced the plugs and spark plug wires. And he said if that doesn't work then they would have to
take the engine apart and manually clean the the heads at $2400.00.
The car is running better at least it is not chugging. But the CEL
came back on and when I just turn the key to Accessories it has this
winding sound just for about 30 seconds. I took it back to Cadillac and he says it is still reading the same P0300 code. I noticed when I put it in Park sometimes the engine will rev up to 2000rpms if I put on the brake it comes back down. Is it possible the Mass Airflow Sensor is Bad or maybe a bad Ignition coil could be causing it to misfire?
Can someone help me with this Lemon of a car I bought. I can't
believe Cadillac put their name on this car and won't do anything to
help me. :cry:
Cheryl
Jan 10, 2006 at 11:23 AM
2CARPRO JACK
  • 11,533 POSTS
could be
Jan 11, 2006 at 7:34 AM
BUZZSAW
  • 1,198 POSTS
[quote:f9058bacc2="cherylmccorry"]I have a 2000 Cadillac Catera
help me. :cry:
Cheryl[/quote:f9058bacc2]
at my dealership we called them cateriables= junkers. and usually after you bought it you couldnt sell it
Sep 17, 2007 at 6:44 AM
