C3500 Rattling (like marbles slowly) stops during acceleration
96,000 MILES • V8 • RWD • AUTOMATIC
GINJA111
Can hear it coming from engine compartment upon idle. Stops or gets dramatically reduced when you accelerate. Upon listening under good it appears to be coming from A/C compressor area, almost sounds like it needs some form of lube or something. It also seems to get better upon engine heating up but can still hear it is going very slow or idling. Almost like someone has a hand full of marbles and is slowly circulating then around in their palm.
Oct 27, 2015 at 8:39 AM
  • 110,251 POSTS
First, remove the serp belt and start the engine for a few seconds to determine if the noise is gone. If it is, turn all belt driven accessories to determine which one is making the noise. Make sure to check the water pump too.
Do this and let me know what you find.
Oct 27, 2015 at 10:31 AM
