1992 Buick Skylark leaking anti freeze
70,000 MILES • 6 CYL • 2WD • AUTOMATIC
JESSICALI1990
I have a leak from the back side of my 92 skylark.It appears to be coming from one of two small hoses in the back.It gets worse when drivenbut doesnt leak much when parked.please help me with this I need this car to get to the doctors and class thank you ahead of time to whom ever can help me. jessicali
Oct 21, 2009 at 12:07 PM
HMAC300
  • 48,601 POSTS
if you think it's leaking out a hose then get the system pressure checked. That will tell for sure. IT leaks while driven because pressure is on the system. When you shut it off it stays on for a little while then dissipates. that 's why it doesn't leak while parked.
Oct 31, 2009 at 10:18 AM
