1997 Buick Skylark
1997 BUICK SKYLARK
MARK235
Engine Cooling problem
1997 Buick Skylark 4 cyl Front Wheel Drive Automatic
coolant is coming out from water pump is cant see where its coming from leaks even when its not running is there a freeze plug behind the water pump what could it be
Jan 31, 2009 at 3:01 AM
BILLYMAC
  • 2,204 POSTS
hi no freeze plug behind water pump. but the water pump has what we call a weep hole when the bearing goes bad antifreeze will leak out of this hole replace the pump/. the only other thing there is a gasket behind the pump billymac
Jan 31, 2009 at 3:05 AM
