Heater problem
1994 Buick Roadmaster V8 Two Wheel Drive Automatic
None of my climate controls are working. It doesnt blow out anything not even air from the vent.
It doesnt blow out no heat from the heater.
Tuesday, October 20th, 2009 AT 9:01 AM
JDL
MECHANIC
Welcome, can you hear the blower motor? Check fuses, maxi fuse 10--60 amp underhood fuse box, the circuit is hot all the time, use testlite. Hvac blow fuse--20 amp, interior fuse box, again use a testlite on the circuit, goes hot when you turn on the key.
