You may have a vacuum leak, get a can of spray gumout, spray the vac lines and maniflod area, when the idle changes, youve found the leak! You want the engine running and spray on the outside but do direct the stream onto the hoses, if it is a vacuum leak, the engine idle will change speed, then you have detected a leak, repair the vacuum leak and see how it runs! If that doesnt do it, you may need a new idle air control valve, it's bolted to the throttlebody. I know you saif you checked it, but they are tricky, one backfire, even if you didn't feel it can destroy em! Is the SES on?
SPONSORED LINKS
Sunday, July 6th, 2008 AT 6:37 PM
