1995 Buick Riviera will not start
TAMSTAR6
  • 1995 BUICK RIVIERA
  • 6 CYL
  • FWD
  • 100,000 MILES
All of the electrical works good. When the key is turned to ignition, other that a click in one of the relays under the hood, nothing
Thursday, December 17th, 2009 AT 10:16 AM
DOCFIXIT
  • 18,828 POSTS
Has battery been tested? Can it be jump started?
Thursday, December 17th, 2009 AT 12:28 PM
TAMSTAR6
Yes, the battery checks out good. I have even tried to jump start, still nothing
Monday, December 21st, 2009 AT 4:18 PM
DOCFIXIT
  • 18,828 POSTS
Need to see if voltage is geting to starter solenoid. Put test light on small solenoid wire at starter. Have a helper try and start does it light?
Tuesday, December 22nd, 2009 AT 3:01 PM
TAMSTAR6
Hey, finally got the snow and ice dug out from around the car so I could get under it. There is "no" fire getting to the solenoid. I double checked my ground location, it was good.
Saturday, January 16th, 2010 AT 1:09 PM
DOCFIXIT
  • 18,828 POSTS
So NO power on small solenoid wire when key in start? Then possibilites are Neutral Safety switch, try staring in Neutral giggle shifter while trying to start. If no go then Ignition switch lower part of steering collumn on top is faulty.
Sunday, January 17th, 2010 AT 1:02 PM
