1991 Buick Riviera dash lights and A/C
1991 BUICK RIVIERA
BILL HAGIS
Electrical problem
1991 Buick Riviera 6 cyl Front Wheel Drive Automatic
dash lights and A/C do not function----recently, the computer was cleared and both worked for several days---then, the dash lights went out and later the A/C failed to operate---the dash lights go on and off randantly---the car does not have to be bumped---is the problem a relay---the A/C is fully charged---it must be electrical???
Jun 22, 2010 at 5:17 AM
BLUELIGHTNIN6
  • 16,542 POSTS
Hello and thanks for donating
Do you have manual A/C controls or a digital (automatic) A/C system? When you say the A/C goes out, do you mean it blows warm air or it doesn't blow anything at all?
Jun 25, 2010 at 5:15 PM
BILL HAGIS
the a/c is factory installed , digital, on that a control button is on the consol and temp controls are indicated----the dash lights come on and off randantly---ther a/c does blow hot air
Jul 3, 2010 at 8:45 AM
BLUELIGHTNIN6
  • 16,542 POSTS
Ok, if clearing the computer helped it for a bit then it would seem as though the computer itself is the fault. Cleaing the computer would not effect any other component aside from the computer itself so if it fixed the issue then swap it with a known good one and see if it corrects the issue.
Jul 4, 2010 at 4:33 AM
