1996 Buick Riviera Cruise and Traction
BEAR22000
We have a 1996 buick riviera, 70,103 miles on the car. we are have a problem with the cruise control, the trip domitor, and the tracktion control.
The cruise controle will not come on after the car is stated, it will come on for a few mins but then go out, i do understand that there can be more then one problem with it but i am not sure what to look for first.
The trip dometor will not turn to 0 at all nothing happens when we push the buttom, do you think it is in the dashboard?, and the tracktion controle is right under the trip domitor butten.
I hope you can help me . If not can you tell me where I can get a book to help me out.
Thank you
P.S. A friend said that he check out the code tester and a code come up as braksw low voilit, if you can tell me what that is.
Apr 2, 2006 at 10:34 AM
KENB79764
  • 52 POSTS
it sounds like the odometer problem is in the dash. a bad brake switch will keep your cruise from coming on and set the traction control code because the computer always thinks the brakes are applied. the switch should be at the top of the accelerator arm under the dash.
Apr 5, 2006 at 2:45 AM
Suggested Repair
Inspect the brake switch at the top of the pedal arm under the dash. A faulty switch can keep cruise control from staying on and set a traction-control code by making the computer think the brakes are applied. The trip odometer that will not reset is likely a dashboard problem.
Conversation Summary
The owner of a 1996 Buick Riviera with about 70,000 miles reported cruise control that comes on briefly then drops out, a trip odometer that will not reset, and a traction-control issue. A code reader reportedly showed a brake-switch low-voltage code. The expert said the odometer fault is in the dash and that a bad brake switch can disable cruise and set the traction code because the computer thinks the brakes are applied. The switch was described as being at the top of the pedal arm under the dash.
