2003 Buick Rendezvous My ignition is locked will not turn
59,000 MILES • 6 CYL • FWD • AUTOMATIC
RUSSF730
at first the key wouldnt go in but i wiggled it a little and it finally went in. Then with the key in the ignition it wouldnt turn, i tried pulling the steering wheel to each side , i tried rocking the truck it just wont turn what is it that i should do just to get it started?
Jan 28, 2009 at 9:17 AM
  • 110,248 POSTS
First try a different key. I've seen them worn to a point they no longer work. If no luck, the tumbler must have gone bad and will most likely need replaced. They do make a lubericant for tumblers, sou could try that.
Feb 16, 2009 at 10:42 AM
