2002 Buick Rendezvous Can't put key in ignition
112,000 MILES • 6 CYL • AWD • AUTOMATIC
HANDLWCARE58
It was working fine when I arrived at work, but when I got in to head home, I couldn't get the key in the ignition....could it be to locking assembly? Is it a major cost??
Thanks!
Aug 26, 2008 at 6:05 AM
DENNYP
  • 1,824 POSTS
Try a small squirt of wd40 in the cylinder. You will probably have to replace the cylinder assembly.
Aug 26, 2008 at 2:32 PM
HANDLWCARE58
Thank you! Is it costly???
What about having to re-program the key fob? Does it matter if there is any anti-theft device on the car?
Aug 29, 2008 at 11:51 PM
