The ignition switch foes not turn and the steering wheel does not lock
Jan 21, 2009 at 10:58 AM
✓Experienced Mechanic
Hi:
If the key doesn't turn, the tumbler may be bad. I have even see cases where the key was worn to a point it would no longer work. Try a different key if you have one. let me know what happens.
Jan 21, 2009 at 11:54 AM
ALBOB13
MEMBER
I have tried both keys and neither works. The steering wheel is not locked either. I am afraid the transmission may not be in park, but with out the ignition switch being able to turn the shifter can not be moved either.
Jan 21, 2009 at 12:08 PM
If you were able to remove the key the last time it worked, it should be in park. With everything you described, it truly sounds like the tumbler assembly needs replaced.
