2002 Buick Rendezvous Filler Neck Leak Fix
DEAN1969
3.4 engine 78,000 gas tank leaks where filler tube connects to tank. this tank is plastic. i found there maybe a check valve here. question is, can a plastic weld be made to repair the leak, right whre these two meet?
Apr 15, 2007 at 3:38 AM
MERLIN2021
  • 17,250 POSTS
if they are 2 seperate parts, take the filler tube off an put a new seal in.
Apr 17, 2007 at 3:54 AM
DEAN1969
i was told there is no replacement seal. there is a plastic weld there,replace tank, gm. thnks. anyway
Apr 18, 2007 at 3:24 AM
Suggested Repair
If the filler tube and tank are separate parts, remove the filler tube and install a new seal. The owner was told no replacement seal exists because the joint is plastic-welded, and GM advised replacing the fuel tank.
Conversation Summary
The owner of a 2002 Buick Rendezvous with a 3.4 engine reported a leak where the filler tube meets the plastic fuel tank and asked whether plastic welding could repair it. An expert said that if the parts are separate, the filler tube should be removed and a new seal installed. The owner later reported being told there is no replacement seal, the joint is plastic-welded, and GM recommends replacing the tank.
