Buick Rendezvous AC Blows Warm Air
MURPH1
I was told that the control module can be reset by disconnecting the battery so that it will blow cold air. Right now it is blowing warm air and the freon is not low.Is this correct and if so what procedure do I need to follow.
May 22, 2007 at 5:51 AM
LSUSSEL
  • 252 POSTS
when you disconnect the battery you reset everything, the ecm clock everything, so yes try that and that should fix the issue, if that does not, reply to this and we will go from there, im here to help.
- lee
May 27, 2007 at 4:08 PM
Suggested Repair
Disconnect the battery to reset the climate control module and ECM, then reconnect and check whether the A/C blows cold. If it still blows warm, further diagnosis is needed.
Conversation Summary
The owner of a Buick Rendezvous says the A/C blows warm air even though the refrigerant is not low, and asks whether disconnecting the battery resets the control module and what procedure to follow. The expert says a battery disconnect resets the ECM and related systems and recommends trying that first, then following up if cooling does not return.
