2002 Buick Rendezvous Condenser Leak
MADISONHUBBARD99
I have a 2002 buick rendezvous cx front wheel drive. I know my condenser is leaking and needs replacing. I was told by a repair place that thye recommend of other things to be replaced by them when replacing the condenser "as a precaution". Does anyone know what should be replaced with a condenser if anything. It is the difference between $750 and $1450. I do not want to replace anything unless it absolutely needs it. Thanks :D :D
Jul 6, 2007 at 1:56 PM
DENNYP
  • 1,824 POSTS
[quote:237ac50ea6="madisonhubbard99"]I have a 2002 buick rendezvous cx front wheel drive. I know my condenser is leaking and needs replacing. I was told by a repair place that thye recommend of other things to be replaced by them when replacing the condenser "as a precaution". Does anyone know what should be replaced with a condenser if anything. It is the difference between $750 and $1450. I do not want to replace anything unless it absolutely needs it. Thanks :D :D[/quote:237ac50ea6]unless the refrigerant system has been empty for a while,you should be able to just change the condenser and charge the system.
Nov 5, 2007 at 12:59 PM
Suggested Repair
Replace the leaking condenser and recharge the system. Extra parts are not needed unless the refrigerant system has been empty for a while.
Conversation Summary
The owner of a 2002 Buick Rendezvous has a leaking A/C condenser and was advised by a shop to replace other parts as a precaution, substantially raising the cost. The owner wants only necessary work. An expert said that if the system has not been empty for a while, replacing the condenser and charging the system should be sufficient.
